OK, so I am happy with the performance of the new driver, but it came with a new.xml that I cant understand how to map axis so Yaw & Roll don't swap when the zoom is set to Up / Down.
Some assistance, please?
Swap Yaw & Roll on RhinoFS.xml
Yianni - Virtual Jewelry
Re: Swap Yaw & Roll on RhinoFS.xml
Do you want to change this permanently for Rhino, or be able to swap back and forth between the two zoom configurations?
If the former, when you change the setting in our GUI, it writes the changed Axes into %appdata%\3Dconnexion\3dxware\cfg\RhinoFS.xml.
You can open this file with your favorite editor (we use notepad++). Delete the Axes which have the change you don't want (HIDMultiAxis_Ry&Rz).
