3DxProfileServer.exe Ultrahigh CPU and ram usage after update (3DWare 10.5.14 3DxWinCore 17.5.14.16045)
Niritio
Post by Niritio »
Hi. I recently updated the controllers for my Wireless Spacemouse.
I noticed that after a couple of hours suddenly the 3DxProfileServer.exe process consumes from 50% up to 95% of the CPU while in idle and more than 1.5 GB of ram.
This appear to happen in idle or in use, doesn't matter.
This didn't happen before the last update (that the software prompted me to do). For now, I saw that restarting windows got the process to return to it's normal state (between 0 and 0.9% CPU usage and about 6MB of ram) but the high CPU and ram usage returns after some hours.
Is there any known fix to this?
mnorelli
Re: 3DxProfileServer.exe Ultrahigh CPU and ram usage after update (3DWare 10.5.14 3DxWinCore 17.5.14.16045)
Post by mnorelli »
Experiencing the same here. Very interested in any ideas. The only current fix is uninstalling.
nwhisenton
Post by nwhisenton »
Hi all,
What was happening when the CPU was between that range? Were multiple applications running or a heavy application was running?
Can you please let me know what was happening before the CPU increased that high?
Thank you,
Nia
dkennedy
Post by dkennedy »
Experiencing the same here, just installed the driver package for my spacemouse compact yesterday. All was well with the world while I was using it in some cad work yesterday afternoon. This morning my CPU is pegged out and 60-90% of it is going to 3DxProffileServer.exe
Niritio
Post by Niritio »
nwhisenton wrote: ↑Thu May 02, 2019 6:36 am Hi all,
Thank you,
Nia
I'm sorry for the delay. Have been very busy days.
About the issue. It is still happening.
It doesn't seem to matter either if there is a heavy application or just chrome open, the issue happens in both.
It has been an update between these days and my first post. There was an improvement. I noticed something that appears like a safety trigger. The first time in a session when the CPU usage spikes, the process slowly goes down by its own (e.g. from 65% to 1% in 1 minute); but the second time when the issue appears it doesn't trigger that and the CPU usage keeps ultrahigh until I manually kill the process.
More importantly, after the last update, I feel like the issue appears only after I let my PC unattended. The issue seems to appear either when the monitors dim or when I go back to work (I would think that it happens when the monitors dim, because I hear the fans working a lot when the monitors are off but haven't been able to hear them ramping up at some specific time so I can't tell for sure)
I think is important to mention that I don't have the suspend/sleep mode enabled on my PC, also I have it set up with a "Dell" power profile.
My understanding is that in this "Dell power profile" even if I don't have sleep mode enable some things do go off at the same time that my monitors (hardrive for instance). I also need to mention that I have my system installed in a SSD and a secondary HDD for file storage (I did the switch of my system from an HDD to the SSD like a month before the update when the problem started).
This improvement I mentioned is helping me now to work better because the process doesn't seem to suddenly go up anymore (at least in my experience). But now my concern is that it could be overworking my CPU when I let it unattended (just downloading some files or so).
I hope it would have a solution soon!
Hi all,
we haven't had such reports for the 3DxProfile server so far.
Would you please verify if removing the existing settings as described in this FAQ would solve the problem?
Please let me know what you find out. Thanks.
Bogative
Post by Bogative »
UtaSH wrote: ↑Mon May 27, 2019 5:00 am Hi all,
I registered just to say I am seeing the same issue. It just continuously spikes up for 20 sec ish then goes back down. It does seem to have something to do with loading images in chrome though. I have been noticing sometimes loading web pages it will have a 10-15sec pause before loading pictures and that's when the driver spikes. I thought it was a chrome or some other issue. Once I force killed the driver that behavior of slowing down webpages stopped. This also includes opening html email in gmail.
There is some issue with the driver. Also if it makes a difference my actual spacemouse is turned off when this is happening.
jhendrickx
Post by jhendrickx »
I also registered just to say I am seeing the same issue.
I tried the methods mentioned above but it keeps happening.
Right now I'm dealing with it like this:
- Step 1: When my PC goes into airplane-takeoff-mode I now open task manager and kill the process.
- Step 2: After a while it happens again and I go back to step 1.
after killing the process the mouse works just fine.
dtbrown00
Post by dtbrown00 »
Experiencing the same issue as others. CPU usage spikes when waking up the PC. I have to "end task" the 3dxprofileserver in order to get my Alienware to do anything. Is there a fix? it's very frustrating that a mouse driver is breaking my very capable laptop.
jhendrickx
I have deleted the exe file, no more high cpu usage since..
AlexeyN
Post by AlexeyN »
I am also registered here just to confirm I have the same issue!
nceske
Post by nceske »
Hi there.
The issue is still here, even crashing.
Faulting application name: 3DxProfileServer.exe, version: 1.0.21291.18895, time stamp: 0x616dab00
Faulting module name: 3DxProfileServer.exe, version: 1.0.21291.18895, time stamp: 0x616dab00
Exception code: 0xc0000005
Fault offset: 0x0000000000037b63
Faulting process id: 0x0x3424
Faulting application start time: 0x0x1d9d1a2d70c3722
Faulting application path: C:\Program Files\3Dconnexion\3DxWare\3DxWinCore\3DxProfileServer.exe
Faulting module path: C:\Program Files\3Dconnexion\3DxWare\3DxWinCore\3DxProfileServer.exe
Report Id: d134e590-2e2f-4866-acca-1c10e39d3c6d
Faulting package full name:
Faulting package-relative application ID:
abhijit_singh
Post by abhijit_singh »
3rd grade software .. 1GB Ram consumed by 3d Connexion services.
Anything else is close to 10MB on a fresh win 11 install.
What needs a Spacemouse and a Cadmouse to use 1GB of system ram?
Since I mentioned CADMouse, this POS is the 3rd replacement and still the scroll wheel is misbehaving.
What are you guys even doing? Upgrading to USB C in 5 years?
AmroSalih
Post by AmroSalih »
