Opera Browser Scrolling?
NikFromNYC
With standard installation both Chrome and Firefox let a Space Navigator scroll the page but what's the trick to getting the Opera browser to do the same thing?
NikFromNYC
Re: Opera Browser Scrolling?
In %appdata% I did find an Opera configuration file:
(c) Copyright 3Dconnexion. All rights reserved.
$Revision: 14618 $
<AppCfg Default="false" xmlns="" CfgFormatVersion="1.2" ThisFileVersion="1.10">
<AppInfo>
<Signature>
<Name>Opera Internet Browser</Name>
<ExecutableName>opera.exe</ExecutableName>
</Signature>
<Options />
</AppInfo>
<CfgProperties>
<InheritsFrom>STR_DEFAULT_KMJ</InheritsFrom>
</CfgProperties>
<Devices>
<Device>
<VendorID>0</VendorID>
<ProductID>0</ProductID>
<AxisBank>
<Name>Default</Name>
<ID>Default</ID>
<Axis>
<Enabled>true</Enabled>
<Input>
<Min>-512</Min>
<Max>511</Max>
</Input>
<Output>
<Reversed>false</Reversed>
</Output>
</Axis>
<Axis>
<Input>
<Min>-512</Min>
<Max>511</Max>
</Input>
<Output>
</Output>
</Axis>
<Axis>
<Input>
<Min>-512</Min>
<Max>511</Max>
</Input>
<Output>
</Output>
</Axis>
<Axis>
<Input>
<Min>-512</Min>
<Max>511</Max>
</Input>
<Output>
</Output>
</Axis>
<Axis>
<Input>
<Min>-512</Min>
<Max>511</Max>
</Input>
<Output>
</Output>
</Axis>
<Axis>
<Input>
<Min>-512</Min>
<Max>511</Max>
</Input>
<Output>
</Output>
</Axis>
</AxisBank>
</Device>
</Devices>
<AuthorInfo>
<DriverVersion>17.6.0.16266</DriverVersion>
<LastChange>
<Tool>3DxSmartUI.exe</Tool>
<Version>1.2.19147.16250</Version>
<Date>6/28/2019 5:26:10 PM UTC</Date>
<User>Operator</User>
</LastChange>
</AuthorInfo>
</AppCfg>
$Revision: 14618 $
<AppInfo>
<Signature>
</Signature>
<Options />
</AppInfo>
<CfgProperties>
</CfgProperties>
<Devices>
<Device>
<AxisBank>
<ID>Default</ID>
<Axis>
<Input>
<Min>-512</Min>
<Max>511</Max>
</Input>
<Output>
</Output>
</Axis>
<Axis>
<Input>
<Min>-512</Min>
<Max>511</Max>
</Input>
<Output>
</Output>
</Axis>
<Axis>
<Input>
<Min>-512</Min>
<Max>511</Max>
</Input>
<Output>
</Output>
</Axis>
<Axis>
<Input>
<Min>-512</Min>
<Max>511</Max>
</Input>
<Output>
</Output>
</Axis>
<Axis>
<Input>
<Min>-512</Min>
<Max>511</Max>
</Input>
<Output>
</Output>
</Axis>
<Axis>
<Input>
<Min>-512</Min>
<Max>511</Max>
</Input>
<Output>
</Output>
</Axis>
</AxisBank>
</Device>
</Devices>
<AuthorInfo>
<LastChange>
</LastChange>
</AuthorInfo>
</AppCfg>
Interesting. That file is wrong.
Delete that file in %APPDATA% and it should start working.
NikFromNYC
Indeed, thanks! Thought I had to learn proprietary code.
LanaMiller
Im not good with coding, Can you make it simple like step by step?
