Spaceball 5000 serial with SW 2008
I'm beta testing Solidworks 2008 and need to know if you will have a dll for the Solidworks addin to use the Spaceball 5000 during testing.
Hi jalcad
3Dconnexion doesn't support serial devices under Windows any more. Please upgrade to an USB device.
agoenczi
Is there any program to trade in my current serial versions for a USB device. I know several companies that have the serial devices that are currently using them with SW and other programs. True USB is the way things are going but why not provide the support for your customers that have been using the Spaceballs and quit forcing them to continue to buy buy buy.
Hi jalcad
I am sorry we had a trade-in program until December the 31-th 2006. At the moment I can suggest you only a new device (USB): take a look to our homepage; I'm sure you will find something suitable for your application (-s).
agoenczi
SolidWorks 2008 Serial SpaceBall 4000/5000/Spacemouse FIX!
In the SolidWorks.com customer portal knowledge base I found this solution. I tried it out to test it and modified the solutions referenced driver version from 3.3.2 to the 3.4.2 which is the only one available.
Also after installing the older driver 2.8.2, install the 3.4.2, but only the SolidWorks plug in. If you install more then that it will not work.
S-016552
Q: I have a serial version Spaceball 4000/5000 /Spacemouse Magellan, and I cannot find a driver for your new software. Is there a way my 3Dconnexicon product can work in SolidWorks 2008?
A: Use the following workaround:
1. Load 3DxSoftware 2.8.2. , found in the Space Ball 4000 from 3Dconnexicon http://www.3dconnexion.com/support/driv ... v2-8-2.exe
2. Download 3DxSoftware 3.4.2. , found in the Space Ball 5000 USB http://www.3dconnexion.com/support/driv ... v3-4-2.exe
3. Use WinZIP to unzip 3dXSoftware 3.3.2 and install only the SolidWorks plug-in.
S-016552
Just to clarify our position on the information on JRICHTER's post.
That procedure may work but the resulting system configuration is unsupported. That means that our Customer Service department is unable to follow up any support requests if a customer installs software in the described manner.
There is also no assurances that this "hack" will continue to work with future releases of 3Dconnexion software.
Hi summersja,
The link is unavailable because release 3.4 has been replaced by version 3.5.
The latest builds of 3Dconnexion software can be found in the download page.
Forum users should avoid deep linking into 3dconnexion.com.
Are the older drivers available in an archived section or are you keeping these from us to force us to purchase new devices. Since you are no longer supporting the serial devices, the least you could do was provide the add in for Solidworks to keep using the serial spaceballs. Also the work around came from Solidworks tech support during beta testing 2008.
Hi jalcad,
You will find the latest available release for your device on the download software page. The software will be found there for a number of years after the device stops being manufactured.
We do not keep old software away from customers to force them to purchase new 3D mice. The most recent software is always provided and software that is not actively maintained can be found in the archive.
I'd like to point out that we provide software updates for devices no longer in production but still in "extended support". The SpaceBall 5000 USB and the SpaceMouse Plus USB are still being actively supported. There is no issue in using these model types in SW2008.
Serial device support ended in late 2006.
I have not tested the configuration of 3.5.5 personally. I may have jumped the gun here. Be aware that at any time there may be a newer driver that would disallow this compatibility so advice it to keep your driver downloads if you find one that works. -Edited 11-13-07 to preface the below comments. -Joe
Looks like they made good on there threat to hamstring serial devices with there 3.5.5 as quoted:
"There is also no assurances that this "hack" will continue to work with future releases of 3Dconnexion software. -Nuno Gomes"
And despite blaming Solidworks for the mismatch: EDIT And thanks to FRED.
"Summers,
Due to changes by SolidWorks, old devices cannot be used in SolidWorks 2008. This includes SpaceMouse Classic, Cadman, SpaceMouse Plus serial, SpaceBall 4000/5000 serial. These devices are not officially supported in SolidWorks 2008.
We have a promo going on with Solidworks users to get 25% off select devices.
http://www.3dconnexion.com/swpromo/en/"
And also this
"We do not keep old software away from customers to force them to purchase new 3D mice. The most recent software is always provided and software that is not actively maintained can be found in the archive. -ngomes"
It is hard to believe that they did not see my post as a "BUG REPORT" to correct this oversight so it would not work with SW2008 and serial devices.
If 3DConnexion is serious about the above comment of not wanting to "force users to purchase new 3D mice", then they should use my post as an Enhancement Request to there Driver and allow this functionality between SW2008 and the serial products.
This is clearly a CHOICE on there part, if the hack works, then there is CODE that would allow this compatibility. But I understand that doing so would not help new product sales (except when you consider the scratch my back I scratch your back way of doing business).
"Summers,
And also this
Here is the blame on Solidworks (By Fred):ngomes wrote:I believe this statement to be unwarranted.JRICHTER wrote:And despite blaming Solidworks for the mismatch
Can you please be more specific and show the Forum where do we make such a remark?
Fred wrote:Summers,
