C4D R21, axis's are all swapped around and I m unable to correct it in the settings. Is this an issue anyone else is having? If so will there be an update soon?
Thanks in advance.
Cinema 4D R21
Re: Cinema 4D R21
Reverse all the 6 axes in 3DxWare advanced settings panel.
Re: Cinema 4D R21
Hello signaturecore,signaturecore wrote: ↑Tue Sep 24, 2019 2:07 am C4D R21, axis's are all swapped around and I m unable to correct it in the settings. Is this an issue anyone else is having? If so will there be an update soon?
Thanks in advance.
we tried what you described, but we were not able to reproduce. We found the axes in C4D being correct. Can you please contact Maxon's Support Team to ask if there is a possibily to reset the navigation?
Would be nice to learn what you find out.
Re: Cinema 4D R21
Settings are now in the tab "view"signaturecore wrote: ↑Tue Sep 24, 2019 2:07 am C4D R21, axis's are all swapped around and I m unable to correct it in the settings. Is this an issue anyone else is having? If so will there be an update soon?
Thanks in advance.
