Autodesk Map 3d 2007
William Drake
We are using Autodesk Map 3d 2007 and need drivers for the mouse work. Please Help.
Dear Mr. Drake,
What operating system are you using?
Which of our navigation devices do you have?
Drivers are available on this website on the 'Driver Download Page' under the 'Support' Menu.
http://www.3dconnexion.com/support/downloads.php
Sincerely,
Bryan
Sincerely,
Bryan
William Drake
William Drake
Inside Autodesk Map 3D navigate go to Setup - Load Application...
Does "3dxautocad.arx" appear in the loaded applications-tab? If not please try to load it manually - it should be located at
Do you use a special version of Map 3D - for example an educational/student licence?
C:\Program Files\Autodesk Map 3D 2007\Robert Stadie
