Space Navigator on SketchUp 2020 Zooming problem
Re: Space Navigator on SketchUp 2020 Zooming problem
Hello –
First post here. Since 2014, I am an avid user of 3DConnexion spacemice, thank you!
I regularly teach Sketchup to companies and higher education, meeting hundreds of users every year. I have always encouraged my students to acquire a 3DConnection spacemouse. I have tree spacemice and love them all. I typically use the classical standard 3DConnexion spacemouse with the latest version of Sketchup Pro.
A very frequent user behaviour is to navigate the model using both the spacemouse and the standard mouse at the same time. This helps momentarily boost the navigation. It is much faster and gives much more control than only using one device at a time. In contrast to many other 3D modelling applications, Sketchup has only one viewport. Therefore, fast and controlled mouse navigation is especially important in Sketchup. Veteran Sketchup users navigate frequently and aggressively. The best way to navigate in Sketchup is to use both a standard mouse and a spacemouse concurrently. This makes as much sense as using both hands to steer a bicycle.
However, something has happened. The issue started around the beginning of 2019.
The issue consists in 3DConnexion's 3DXWare driver conflicting with native Sketchup navigation. The issue is seen most clearly when using the spacemouse to zoom while simultaneously using the standard three-button mousewheel to zoom. When you zoom in on both devices, or zoom out on both devices, the whole viewport shudders, quakes, and jerks about violently, as if it were having an epileptic seizure. The Sketchup viewport behaves as if the two devices were constantly fighting for priority instead of cooperating. It looks as if one device were pulling inwards and another were pulling outwards, even though inputs in fact are towards the same direction.
This behaviour, besides not being what users expect, is very distracting and unpleasant, and renders simultaneous device navigation, especially zooming, effectively unusable.
Users' justified expectation would instead be that the 3DConnexion driver behaved as it did up to late 2018: when inputs from the two devices point in the same direction, the viewport result pulls in the same direction, and faster than if only one input were active. The result should at all times just sum the two input vectors.
And yes, this is the exact same issue as jwhida, the original poster, describes above. The issue is clearly illustrated in Jwhidas video here: https://www.dropbox.com/s/ncbq223vjmtd8 ... l.mov?dl=0
I use Sketchup 2020, but this same issue occurs also with all earlier Sketchup versions I have checked, e.g.:
Sketchup Pro 2020
Sketchup Pro 2019
Sketchup Pro 2018
This issue affects at least these driver versions:
3DxWare64_v10-7-0_r3248.exe
3DxWare64_v10-6-1_r3016.exe
3DxWare64_v10-6-0_r2972.exe
3DxWare64_v10-5-14_r2941.exe
The only workaround I know is using older drivers. The newest driver that I have confirmed to not suffer from the issue described above is from 2018:
3DxWare64_v10-5-12_r2890.exe
However, Sketchup is moving on. Typically, Trimble releases a new Sketchup year version around the end of each year. Sooner or later, there may be breaking changes in Sketchup that make older 3DXWare drivers completely useless. If this happens, the 2018 driver workaround will no longer work.
• Are 3DXWare developers aware of this issue?
• What is the status of this issue?
• Would you please fix this issue in your next release?
Sketchup Pro 2020
Sketchup Pro 2019
Sketchup Pro 2018
Hello Matheron,
Thanks for sharing this, I've tried reproducing the issue on my end and i couldn't get the same outcome per your provided video.
Do you have different plugins or add-ons within Sketchup? Sometimes this might cause an issue similar to what you encountering right now!
If you do have add-ons/plugins then please try to disable some and see if the issue still persist.
If you still encountering the issue then we might need to generate a diagnostic folder to see why this happening on your end which you might need to create a technical case and submit it to us here https://3dconnexion.com/us/support-request/login/
Will be waiting for some updates on your end.
Regards,
Abdul. A
Regards,
Abdul. A
Hello Abdul -
Thank you. This issue is real.
I can reproduce it in all combinations of installed Sketchup extensions that I have tried. This issue affects all tested versions of 3DX Ware since sometime late 2018, i.e. more than two years back. This issue persists across all versions of Sketchup I have tested.
I have submitted a support case to 3DConnexion. Christophe at 3DConnexion's support staff has clearly recognized this issue. 3DConnexion has labelled this issue internally as WIN-632.
Please note that:
1) The WIN-632 issue does not only concern zoom. It concerns panning, and orbiting,and zooming . In fact, all tandem navigation is clearly and adversely affected.
2) The WIN-632 issue is an obvious regression. For many years, mouse and spacemouse navigation have been working together excellently. Then, suddenly, something broke in the 3DXWare Drivers. Concurrent navigation in effect stopped working.
3) During the many years that mouse and spacemouse input have been working excellently together, perceived performance was higher. The reason is that users could navigate their modelspace much faster and more controlled than we can today.
I would just like to warn all other users. In Sketchup, you will no longer be able to use your mouse and your spacemouse concurrently.
We very much look forward to a solution.
Please note that:
Spacemouse + SketchUp Zooming Issue
No new driver. No solution. No reply.
• What is the current status of this issue?
This issue still exists, and is very frustrating.
Has 3Dx abandoned support for Sketchup Pro ?
Please advise if Sketchup is a priority for support or not
sincerely
sincerely
the above link does not workaalsalihi wrote: ↑Mon May 04, 2020 6:46 am Hi Jwhida,
Thanks for the video, that was really odd! We would need to generate a diagnostic folder to see why this behavior is happening when using both devices in Sketchup. Please create a technical case here https://www.3dconnexion.com/service/tec ... mular.html
Will send the needed instructions after you create the case (Please make sure to include a link to this post in your case).
Regards,
Abdul. A
Here is a link to the video again, sorry I deleted the old file
https://www.dropbox.com/s/ieob8oqy9lngl ... l.mov?dl=0
Hi Jwhida,
I was able to check the video and your issue is that within the driver there's only 1 manipulation device to control the zoom feature which is why its stuttering. Basically, both the mouse wheel and the 3D mouse are trying to control zoom. To avoid the stutter effect, it would be necessary to restart navigation in the NL whenever the mouse wheel change the view parameters. This would likely cause other performance problems since the NL is optimized for a single device manipulating the application's view.
We have a enhancement request created for this as WIN-775 within our system with no ETA. If you have any questions then you can contact our Technical Support Team at https://3dconnexion.com/us/support/
Regards,
Abdul. A
Regards,
Abdul. A
Hi Abdul,
I just installed the latest driver, and this problem still persists.
In earlier versions things worked wonderfully. The combination of scroll and spacemouse zoom worked harmoniously.
You say it is a shortcoming of the driver, obviously something has changed.
This really compromises effective use of the spacemouse with ketchup
Hi jwhida,
This request is not under consideration at the moment but will try to contact our product management team and see what can be done.
Regards,
Abdul. A
Regards,
Abdul. A
mark-in-seattle
Hyper-sensative movement in all axis when Doing Closeup Work
With the current MacOS Catalina drivers I am experiencing the same awful hyper-jerky movement using my 3Dconnexion SpaceMouse-Pro wireless when I try to zoom in for closeup work on a Sketchup-Pro model. Almost un-usable for any close work because the SpaceMouse is hyper-sensative to any movement of the control axis and flies wildly off into space in the model 50'ft away from where I was working on a 4"inch area of the model.
The 3Dconnexion control panel widget is turned down to the lowest "speed" setting and still for closeup work in a Sketchup model the SpaceMouse is just totally unuseable. I will now NOT recommend any Sketchup users purchase as SpaceMouse for their Sketchup work ... just too frustrating and a time killer.
