3DSMax 2020/21 Keeps switching back and forth to perspective view
Re: 3DSMax 2020/21 Keeps switching back and forth to perspective view
I have downgraded 3DxWare 10.6.0 and it seems to have stopped the issue.
I found a download link to that version here: https://www.touslesdrivers.com/index.ph ... _langue=en
To get it working in 2021, I just copied the 3dxstd.gup from "Program Files\3Dconnexion\3DxWare\3DxStudio64\Contents\win64\2020"
into "Program Files\Autodesk\3ds Max 2021\stdplugs" and it works.
Early days but so far no glitching when in cameras!
I hope this works for you all too! Good luck.
This solves the viewport glitching issue, but now my space navigator buttons won't work.GregMediasphere wrote: ↑Fri Feb 12, 2021 3:12 am I have downgraded 3DxWare 10.6.0 and it seems to have stopped the issue.
Please 3D Connexion, fix the bug or add support for max2021 to 10.6 drivers!
Same issue here.
Dear developers! Could you share the mentioned patch by the link below with us? Thanks!
https://forums.autodesk.com/t5/3ds-max- ... ue#M193026
Dear developers!
Could you please provide us with the patch you provided to the guy in the Autodesk forums?
Please contact our Technical Support Team. The colleagues will be able to assist with this.
BTW - the fix will be available in the next driver release .
UtaSH wrote: ↑Wed Mar 03, 2021 3:40 am Please contact our Technical Support Team. The colleagues will be able to assist with this.
BTW - the fix will be available in the next driver release .![]()
Without considering that I have had this problem from 6 July 2020 and an opened ticket...which has been completely forgotten.
Thank you!
Hello studiotetris,
I am very sorry for that. Yes, your case had been escalated to the next level and there it had been overseen. Apologies. I have pushed this - you should hear from us by today.
I try all the two beta drivers and, at the moment, the problems related to switching seem to me completely solved.
But when I move in the scene I have a reply delay in movements and I have a blur effect on all the geometries of the scene when I move the 3dconnexxion mouse...
Still waiting for a reply from support...
This is getting quite ridiculous!
Why can't you just provide the download link to the fix!?
Your support is not responding to this issue.
If there was an alternative to your products on the market, we would have switched ages ago.
Finally new version software in released, and seem to works!!
