I can't seem to get any response from Space Traveler in XSI. I've tried re-running the 3dconnexion installer a couple of times to no avail.
Is there something you need to do within XSI to activate it?
Problem with XSI on XP
KevinThorp
KevinThorp
Try the manual method of loading the plugin
* Manual Installation to User Addon directory:
Drag and drop 3DxSI.xsiaddon to XSI.
Thats it.
To manually install to the factory/work group directory:
Install the add-on using the XSI Add-on Manager:
Select File->Add-on->Install... from the main xsi menu bar
To find this file you will have to browse for it.
C:\Program Files\3Dconnexion\3Dconnexion 3DxSoftware\3DxSI
Thats it.
KevinThorp
