Can you suggest a target application so that we can confirm this? Please try with an application that is included with a system installation (like Safari, TextEdit or similar).
Thanks @ngomes for your answer, but that didn't solve the problem. The 3D SpaceMouse Wireless is not recognized on the M1 MacBook Pro on this end via Bluetooth. Thus far, when I access the Bluetooth area within the System Preferences app, it never shows up. The only way I can get the device to work with the Mac is through a wired connection through my ANKER Docking Station, which has a regular USB 3.0 slot. If the 3D SpaceMouse Wireless can be recognized via Bluetooth on M1 Macs, please let me know, as I haven't seen it yet.
This feature alone (considering IF everything on the device works exactly as it is right now in a wired connection) would help greatly when going away from the office, say, to sit in a library with this device connected via Bluetooth, as it would save on having to carry yet another cord.
The SpaceMouse Wireless device type does not have Bluetooth support. The device can be used wirelessly if paired to a Universal Receiver or, as you pointed out, connected by a cable.
I’m trying to use this is Safari and Finder, in order to show all open tabs
Seems to work fine.
Note that Safari has a pre-defined configuration. You will need to edit that instead of the "Any Application" configuration.
In other words:
- Open the "3Dconnexion" pane in System Preferences.
- Change to the "Buttons" tab.
- Select the "Safari" configuration.
- Select the button to change the assigned action.
- In the "Mapping" field, select "Type Keystroke".
- Click on the "Keystroke" field, press the backslash key on your keyboard ("\") and tick the "Command" and "Shift" check boxes.
Guys, plugins didn't work yet on this driver version?
After update on BigSure this plugin not work anymore
- CleanShot 2021-09-03 at 09.10.38.png (117.83 KiB) Viewed 86890 times
Most applications and plugins should work fine but there may be vendors that still need to make corrections to their products.
Perhaps Figma is one such case. I suggest getting in touch with the Figma developers. If they have an issue, 3Dconnexion can assist them to sort it out, just like we have done with other vendors.
Unfortunately it doesn't work. Nothing happensngomes wrote: ↑Mon Aug 30, 2021 6:42 amSeems to work fine.
In other words:
Thank you, great to hear this!
Also, please, remember of MAC-281. Really need this to use 3Dx as on Windows
I connected with the developer we try to find whats is wrong.ngomes wrote: ↑Fri Sep 03, 2021 12:29 amMost applications and plugins should work fine but there may be vendors that still need to make corrections to their products.
Here screenshot we try get gamepad id from plugins:
