Downloaded current driver version (3DxWare64_v10-8-2_r3385.exe) today and found out that only allows for the zoom in/out function on Fusion360 and nothing more.
After an hour of installing/reinstalling/play with settings, etc, I used older driver (3DxWare64_v10-7-4_r3385.exe) and it works correctly.
I am missing something?
Newest Driver does not work on Fusion360
Re: Newest Driver does not work on Fusion360
Hi cbtech ,
It seems a configuration issue as there's nothing wrong with the new driver. You might need to do cleaning for driver configuration in which our Technical Team can assist with. Please give them a call here https://3dconnexion.com/us/support/# or send a Technical case here https://3dconnexion.com/us/support-request/
Regards,
Abdul. A
Regards,
Abdul. A
I just bought & received a SpaceMouse Compact to use with Fusion 360 and ran into this same issue. I installed the latest drivers and got the same behaviour as the cbtech. I tried uninstalling, re-installing, rebooting etc. until I found this thread. I went to the driver archives on 3dconnexion's site and downloaded 3DxWare64_v10-6-4_r3119.exe. Uninstalled the old driver, installed this one, booted Fusion and it worked immediately.
I'm running on Microsoft Windows 10 Pro Version 10.0.19043 Build 19043.
Ensure Fusion 360 is updated to the latest version.
Then, in Fusion 360, go to Preferences, select "Preview Features" from the left pane and tick the "SpaceMouse" check box. Restart the application and you should be set.
