ArchiCad mouse only works in one window at a time
Kevin Cabral
Post by Kevin Cabral »
When having more than one archicad file open at the same time it will only work on the latest file opened. Anyone know how to fix this?
DavidV
Re: ArchiCad mouse only works in one window at a time
Post by DavidV »
Hello Kevin,
I can trouble shoot on me end. Are you on Big Sur or the previous MacOS?
kittonian
Post by kittonian »
Nothing to trouble shoot. This is exactly what I experience as well. Now try having ArchiCAD and Cinema 4D open at the same time. It'll work in C4D but not ArchiCAD.
alexandre.Glt
Post by alexandre.Glt »
I agree.
When I use Spacemouse with archicad. It works only with the last file opened.
Very problematic when you work on several files in the same time. (we do all the time).
Also the 3D connexion home app does not start at all.
Macbook pro M1 with Big Sur.
aalsalihi
Post by aalsalihi »
Hi alexandre.Glt,
Are you on the latest beta driver? Here's a link to check https://3dconnexion.com/us/support/faq/ ... 1-big-sur/
It seems an issue and if its something on our end to fix then we can create a bug. Please contact our Technical Support team to open a case and send a log files here https://3dconnexion.com/us/support-request/
Regards,
Abdul. A
alexandre.Glt
I did it right away.
but unfortunately, the new version of the beta driver hasn't fix the problem.
alexandre.Glt wrote: ↑Tue Oct 19, 2021 10:53 am but unfortunately, the new version of the beta driver hasn't fix the problem.
This was asked elsewhere in the Forum but can you say when was possible to have more than one instance of ArchiCAD working with a SpaceMouse?
alexandre.Glt
when we were on Mojave mac os 10.14. and your driver 10.6.7.
By the way, we have other computers in the office with this setup and we don't have any problem. we can use space mouse in any instance..
the problem is on macs operating on big sur
alexandre.Glt
no answer?
it is a big issue in our workflow :(
alexandre.Glt
ah ok, you listed this issue with reference MAC-320.
alexandre.Glt wrote: ↑Thu Oct 28, 2021 4:25 am ah ok, you listed this issue with reference MAC-320.
There were multiple threads on this issue. We mentioned MAC-320 on this post.
