Vista 64 vs space navigator.. issues?
Any known issues with the space navigator's drivers and any vista 64 software? It was working fine with a new vista install, but somewhere in installing software, the spacce navigator software broke.
Un installing and re-installing doe not solve the issue.. the control panel and driver will not load, and the lights do not come on on the sn itself.
I saw something similar to this under xp32, and a rollback solved that issue, but I've been setting up the brand new vista install, and I don't want to have to reinstall everything again just for the space navigator.
Are there any security settings that could interfere, or any known incompatibilities?
Gareee,
Try this:
If you haven't saved the 3.5.6 driver to your computer:
Download the 3.5.6 driver and save it to your desktop.
Then
Make sure the Navigator is connected to the computer's usb port:
Not throough a hub, adapter, monitor or docking station.
Remove 3dconnexion from add/remove programs
Go to:
My computer C:\program files
Delete 3dconnexion.
Empty recycle bin.
Go to:
start/run and type regedit then click ok.
Click file/export and set it to save on the desktop.
Name the file registry1
Click save.
In the registry editor open hkey current user/software
Delete 3dconnexion
Open hkey local machine and do the same thing if 3dconnexion is in there.
Reboot the computer.
Install the driver you saved to the desktop.
Try this:
Then
Go to:
Delete 3dconnexion.
Empty recycle bin.
Go to:
Click save.
Delete 3dconnexion
Chris
I had saved the driver locally.
Followed your steps, and the navigator is still dead. I even tried to run the instaler and then the control panle for it in admin mode,and that failed as well.
Could it possibly need a different usb connection on my system during install?
I'll install it on my other system here, to verify that the hardware hasn't failed, but I find that unlikely.
FWIW, I didn't get a chance to try the disconnect thing you mentioned, but I did save all this info in case it dies again.
Thanks MUCH! I never realized how much I really like using it till I didn;t have it available again.
BTW, any news of a speedup to the image browser? Comparing it to the windows one, there's quite a slowdown when going from image to image.
