Direct Input Example
Seabra
Post by Seabra »
Anyone have any example of Direct Input with Space Navigator without windows???
I would like to use the Direct Input Example from a prompt, and only read the coordinates of Space Navigator, without showing them in a GUI. I need of their coordinates to use in the other application.
Thanks.
If you don't want to use Windows at all, you are probably best using the HID example.
Seabra
Post by Seabra »
Ok. But, where I find the library "hidsdi.h"?
I need it to compile the example HIDTest.
Thanks.
hidsdi.h is in the Microsoft Device Driver Kit.
Seabra
Post by Seabra »
rodrigo.seabra
Post by rodrigo.seabra »
I'm trying to addapt the HIDtest code to continuously get the rotation and translation parameters that are generated by the SpaceNavigator.
In the function call:
waitResult = WaitForMultipleObjects(_waitListIndex, _waitListHandles, FALSE, INFINITE);
from the example we're discussing, how can I change the parameter INFINITE so that it doesn't wait infinite time for a response from the device?
Or do I have to do any other modification to get what I want?
Thanks in advance.
Read the documentation on WaitForMultipleObjects. If you wait, you will get woken whenever some data is available on the device. If you don't wait you will get woken when the timeout is exceeded, if nothing happens on the handles you are waiting on.
rodrigo.seabra
jwick,
I've changed the parameter INFINITE to 0, but I still have to wait for an interaction to occur. I'm kind of lost here... I don't know which part of the following code makes my application wait for a sign of life from the device:
if (bRun) {
		float vettranslacao[3], vetrotacao[3];
		waitResult = WaitForMultipleObjects(_waitListIndex, _waitListHandles, FALSE, 0);
		if (waitResult <WAIT_OBJECT_0> handle, pDev -> buf, pDev -> capabilities.InputReportByteLength, &nread, FALSE))
Please, help me out... All I wanted was to get the translation and rotation vectors, even if the device is not activated.
Thanks again.
The way you've changed the code, you should return immediately but you won't have any data most of the time.
You can't get the data if there isn't anything there to be got. If you want to get new data at any time and not be blocked in your main thread, you should run a separate thread that just reads the device and provides the data to the main loop of your app any time you need it.
rodrigo.seabra
Oh, so there is a way of just reading the device? Simpler than the example in question? Sorry to be so straightforward, but how can I do it?
Thanks for your patience.
HIDTest is just about as simple as it gets. There is very little going on there. I'm suggesting that you put that code into a separate thread so it doesn't block your main thread.
