Forgive me but i'm not familar with ATL and coercing it into being MFC friendly is proving to be quite offputting. Any chance of an example code lump on how to connect and monitor input with MFC?
Thank you in advance for any help.
VS2005 MFC example?
The problem i'm having (BTW) is that after i've added ATL support to my MFC project i can't declare a com event handler class without causing the compiler to complain i haven't got ATL support (which I do.. arggh).
I'm at the evaluation stage right now - with a view to implementing this as part of our product.
Thank you, much appreciated. We use COM ourselves but in the main just IDispatch derived interfaces as they're easy to implement within the framework of MFC itself. I think it'd be most useful to see an example of a small MFC dialog app handling connection and events - at the moment it's a bit of an uphill struggle (the last time I touched atl was probably about six years ago). Our server-end stuff is all MFC and this is where the device integration needs to go.
Old Archive Disappeared
I cannot find the old win32 sdk any more, where is it in the website?
thanks
thanks
