I have installed the new driver and now I'm allow to use it in Blender as a 3D navigator, but it is still a mouse at the same time. My distribution is Xubuntu 9.04 64, I know Xubuntu is not officially supported but, do you know any solution for that?
Thank you.
Heavy flickering of 3DxWare window under Linux
please try the script below to start the driver. You have to disable the start from the /etc/inittab in case it is active and then start the script from a command line.
Uta Ludwig
#!/bin/sh
usleep 200000
rmmod hid
/etc/3DxWare/daemon/3dxsrv -d usb &
# sleep 1
modprobe hid
Hello Uta and others.
Thanks for emailing me the 1.4.3 beta driver. Sadly I am still experiencing the problem; when I start the driver and the configuration program appears, moving the space navigator causes the options to randomly flicker about and change.
I understand ubuntu isn't officially supported but if others have been successful in getting it to work, could you explain how you've done it?
Ubuntu automatically installs the space navigator as a 2D mouse and I wonder if this is interfering; does anyone know a way to prevent ubuntu from hijacking the space navigator when it's plugged in?
Cheers,
Idris
Cheers,
Idris
Hi idris,
it’s a pity that you still have the same problems.
This sounds really as if you received the old version of the driver. Could you please check if you are using the correct version? Either see the title of the window or launch
Uta Ludwig
- /etc/3DxWare/daemon/3dxsrv -v
- /etc/3DxWare/daemon/3dxsrv -d usb -dbgMotion -dbgButton
Uta Ludwig
Bingo. I just ran the installer again and there was an error because I didn't have the tar.gz file in the current directory - it must have thrown this error before but I didn't notice it in the output messages.uludwig wrote:it’s a pity that you still have the same problems.This sounds really as if you received the old version of the driver.
I've upgraded now and it works
The only problem is that in blender the controls all seem to be upside-down, but I'll find a more appropriate place to post about that!
Cheers!
fromlugdunum
