Heavy flickering of 3DxWare window under Linux
I have installed the 3DxWare 1.4.1 under Linux.
xcube or xvalue are not working correctly. I cannot move the cube nor can I see any output with xvalue.
The only thing which happens is that all buttons in the 3DxWare window are changed frequently while touching my SpaceNavigator.
What is wrong?
Andreas
What is wrong?
Andreas
Dear andpe,
Can you tell us a little more about your setup?
What hardware are you using?
What version of Linux?
Video Cards?
Do you have your device plugged directly into the computer?
What results have had previously or on another system?
Sincerely,
Bryan
Video Cards?
Sincerely,
Bryan
Hello Andreas,
we recently found a problem with the SpaceNavigator on Linux
. No motion data comes through. The internal bug number for this problem is #5067 (for your reference). We are working on a solution and I hope I can soon post here when we have a beta version ready for testing.
Uta Ludwig
Uta Ludwig
Re: Heavy flickering of 3DxWare window under Linux
Dear Bryan,
I just tested on another machine and had the same problem.
Machine 1:
****** XPC SD31P with PentiumD 3.4GHz, Nvidia Quadro FX 1400, 2GB RAM, OpenSuse 10.2
Machine 2:
****** XPC SN25P with Athlon X2 4200+, Nvidia Quadro FX 1500, 2GB RAM, OpenSuse 10.2
The SpaceNavigator is directly connected via USB to the computers.
Hope this helps,
Andreas
Machine 1:
Machine 2:
Hope this helps,
Andreas
Hallo Frau Ludwig,uludwig wrote:Hello Andreas,
we recently found a problem with the SpaceNavigator on Linux. No motion data comes through. The internal bug number for this problem is #5067 (for your reference). We are working on a solution and I hope I can soon post here when we have a beta version ready for testing.
Uta Ludwig
ich hoffe, ich darf hier auf Deutsch schreiben.
Wollen Sie mir sagen, dass die SpaceNavigator zur Zeit gar nicht unter Linux funktioniert?
Bei mir werden immer dann, wenn ich die Maus berühre alle möglichen Sachen im "3DxWare 1.4.1"-Fenster verstellt. Besonders deutlich ist, dass sich der Text auf der ersten Seite bei "Tooltips" beim Berühren permanent verändert.
Haben Sie die gleichen Phänomene? Wann ist mit einem Fix zu Rechnen?
Schöne Grüße,
Andreas
Hi Andreas,
we have a bug fix now for the problem with the SpaceNavigator on Linux. I'll send you a beta version of the driver. It will be version 1.4.3.
Uta Ludwig
Uta Ludwig
Beta driver: 3DxWareUnix 1.4.3
Hi all,
many thanks for all your feedback. I appreciate it.
For those who want to have the beta version of the driver with the fix for the SpaceNavigator, please send me a PM and I will contact you. Please specify your Linux distribution and your platform (x86_64 or i386).
Uta Ludwig
Yes, sure you can have it. I'll send it to you.qxsxfx wrote:May I have the new driver?
Uta Ludwig
Re: Beta driver: 3DxWareUnix 1.4.3
Hi all,
I forgot to mention that I need as well your email address. Please add it to the other information (Linux distribution, architecture).
We still want to do a thorough testing. But as soon as this is done we will provide the driver on our download page.
