proe Build M080, 32bit
Latest version of 3dx ware from the web site. (downloaded today)
We recently just upgraded to wildfire 3 and I have not been able to use the space pilot. Once proe is open and running you can pan and zoom but no spin. The other portion of this is that you can't get the panel to come up with proe open, from either the button or from the task bar. It seems to be locked by proe.
Wildfire 3 and space pilot not working properly
10mrussell
Hi 10mrussel
Please activate the "Update Wizard" as you upgraded from wildfire2. If it doesn't help, remove completely 3DxSoftware as described here. Finally install 3DxSoftware again - it should work and test your device again in Pro/E. Share your experience by posting here.
agoenczi
