Only able to pan and zoon in AutoCAD
Patch
Post by Patch »
I just upgraded from a Spaceball 4000FLX to a SpaceExplorer USB. When I run utoCAD, I am unable to rotate on any axis. I can pan and zoom only. I have unchecked and re-checked every checkbox in the control panel with no change.
I had the same problem with my old spaceball, but I had buttons called 'Screen Mode' and 'Desktop Mode' and when I toggled Screen Mode and then Desktop Mode I was then able to rotate. No such luck toggling settings with the new software.
This behavior is the same in AutoCAD 2007 and 2008.
Here I have this fancy new controller and can't use it. :cry:
Edit: I want to add that I did uninstall the old software before installing the new. Also, I have uninstalled the new software, rebooted and reinstalled with no change.
Hi Patch,
Please refer to this post.
