Hello Guys,
I have already spent a few hours and can not find a solution, please help me!
I'm trying to use the SpaceMouse Pro with Cinema 4D R16, but I cant install the plugin because the OS X Yosemite no longer works with PowerPC files. And the plugin file that came on the CD is a PowerPC.
I do not know if I'm doing something wrong, installed successfully 3DxWare, but when I open the C4D has nothing on the SpaceMouse Pro, and everything moves, I can not move separate objects.
My Settings:
OS X Yosemite 10.10.1
4D R16 Cinema
Please help me!
Do not install the plugin. OS X Yosemite and Cinema 4D R 16
Re: Do not install the plugin. OS X Yosemite and Cinema 4D R
Hi daniellinard,
we were in contact by email and I send you the link to our FAQ #50 "How to enable support for Cinema 4D in Windows". This one helped you you wrote - "only the window with the settings was in a different place". Can you add the information where you found this window? As a help for others with the same problem?
