SpaceMouse Wireless power switch
kbrown
Post by kbrown » Wed Mar 18, 2015 3:10 pm
Does the SpaceMouse Wireless power switch need to have green visible when plugged in to USB?
Re: SpaceMouse Wireless power switch
Post by UtaSH » Thu Mar 19, 2015 6:47 am
Hello kbrown,
if you connect the SpaceMouse Wireless with the cable then it acts like a cabled device. This means it doesn't necessarily be switched on. As soon as you unplug the cable from the device you the power switch at the back of the device has to switched on (green). If you connect the SMW with the cable the green LED on the front side is pulsating when it loads and lights permanently if it is fully loaded.
