Control Cap not Working
danerog
Post by danerog »
All other SpaceMouse Pro keys are functional and work in the Solid Edge ST8 environment, however the control cap does not. It works to control webpages and works fine with OnShape, but just not Solid Edge ST8.
Any help would be greatly appreciated.
Thank you.
Re: Control Cap not Working
Hello danerog,
which driver version is installed on your machine?
Did you install the driver after you installed Solid Edge ST 8? Or did you at least make a "repair" installation after you installed ST8?
Do you start the driver and Solid Edge with the same user or do you start Solid Edge "as administrator"?
