I'd like to submit some suggestions as to how to enhance the navigation using, in my case, SpaceExplorer in 3ds Max.
1) Please, make the 2D button mappable so that I can assign another VIEW for example, so that I can have FRONT, TOP, RIGHT, LEFT and PERSPECTIVE
2) Also, make the splash screen toggleable, I don't need to see that I'm using 3DConnexion's SpaceExplorer each time. The thing is I run multiple Max windows and each time I run one, while working in the other, it pops up for a few seconds which distracts, obscures my view and delays my work. It's seconds, but still quite annoying. The other thing is, for the time it shows up I'm able to open up a recent scene, but the white rectangle just obscures too much of the view.
3) When in ortho views such as TOP, FRONT etc... (I re-mapped them in the settings so that I use native 3ds Max orthos) when panning it switches to a USER view with the same position. While it looks the same, it DOES NOT behave the same, for example, I can't see the GRID anymore as USER view only shows the bottom one like the perspective view. But the worst thing is, since USER behaves more like perspective (in fact, it is a perspective view but with ortho projection, i.e. without the skew) I CANNOT create objects in the TOP/FRONT view manner, it'll draw the object on the bottom, not in front of me!
These minor things can be very easily fixed I believe while it'll BOOST UP the user experience at least in 3ds Max!
I'll appretiate any comments/suggestions but most of all the hot-fix
cheers
