Problem "Unable to load an 3DxService.dll resource DLL
rsantos2005
Hello everyone, I have a Spacepilot PRO. Install the drivers and appears "unable to load an 3Dxservice.dll resource dll". What is the problem?. This occurs in two computers, one running Windows 10 and another running Windows 8.1.I appreciate the help
Re: Problem "Unable to load an 3DxService.dll resource DLL
Hello rsantos2005 -
Are you installing the 3DxWare V 10.3 driver from the downloads page ? Make sure the installer is downloaded to your local PC rather than running from a network resource and that applications are closed.
If there has been a driver from the older driver series installed [3DxSoftware] remove any remaining components with the
clean install steps.
We have sometimes seen AV software block a file during installation. If you are using the same AV software on both PCs , that could be the source. You may need to temporarily disconnect from the internet so you can disable the AV software during the install.
Barbara
Barbara
