i cant imagine im the only looking to get the spacenavigator pe working with maya 8.5 ple. i saw something about downloading some maya script in the download section, but i dont see anything but drivers and honestly this thing is becoming more of a hassle trying to get it working.
can someone please tell me how to get this thing to work with Maya 8.5 PLE?
tia.
maya 8.5 ple
I'm also having trouble getting the SpaceExplorer working with the Maya 8.5 PLE. On startup, these errors come up:
Any thoughts on why this is happening? Has anyone encountered a simlar problem?
Thanks.
If I go into the Plug-in Manager and try to load "3DxMaya.mll" manually, the following error pops up in a dialog:// Warning: Move Camera //
// Warning: Rotate around center of the scene/object! //
// Warning: Fly mode on! //
// Warning: Rotation Scale 1 //
// Warning: Translation Scale 1 //
// Error: Unable to dynamically load : C:/Program Files/Autodesk/Maya 8.5 Personal Learning Edition/bin/plug-ins/3DxMaya.mll
The specified procedure could not be found.
// Error: The specified procedure could not be found.
(3DxMaya) //
// Warning: No Magellan device found. Start 3DxWare and then restart Maya
I assume it's looking at the foundation.dll that is located here:The procedure entry point ??1MObject@@QAE@XZ could not be located in the dynamic link library FOUNDATION.dll.
The 3DxMaya.mll plugin is located here:C:\Program Files\Autodesk\Maya 8.5 Personal Learning Edition\bin
C:\Program Files\Autodesk\Maya 8.5 Personal Learning Edition\bin\plug-ins
Thanks.
Unfortunately the PLE edition of Maya does not support Plug-ins - please see also here:
It is not possible to load plug-ins from the commercial version of Autodesk Maya or third party plug-ins or other versions of Autodesk Maya Personal Learning Edition. Robert Stadie
