i've got a big problem concerning the sample projects... i downloaded both of them and could compile them without any problems...
but when i tried to make a new console project based on those sample projects they simply don't do what I like them to do... (printing numbers which represent forces and momentums applied to the cap on the screen...)
I could compile them and where I'm printing the devicetype it's 6 (for spacenavigator) so the connection to the device should actually be established... but why do all the other values remain 0 even if i move the cap... ???
I'm asking kindly if anybody could explain me what I'm doing wrong... ?
Has anybody got a very basic hello world project which could be shared somehow ?
// testprojekt.cpp : Defines the entry point for the console application.
#include "stdafx.h"
#include "windows.h"
#include "atlbase.h"
#include "objbase.h"
#include <atlstr>
#include "math3d.h"
#include <iostream>
using namespace std;
#define ScaleRotation 1024.0
#define ScaleTranslation 512.0
int _tmain(int argc, _TCHAR* argv[])
double Sensitivity = 1.0;
CComPtr<ISensor> g3DSensor;
CComPtr<IKeyboard> g3DKeyboard;
__int64 gKeyStates=0;
// ------------------ init ----------------
HRESULT hr=CoInitializeEx(NULL, COINIT_APARTMENTTHREADED );
if (!SUCCEEDED(hr))
CString strError;
strError.FormatMessage (_T("Error 0x%x"), hr);
::MessageBox (NULL, strError, _T("CoInitializeEx failed"), MB_ICONERROR|MB_OK);
return FALSE;
CComPtr<IUnknown> _3DxDevice;
// Create the device object
hr = _3DxDevice.CoCreateInstance(__uuidof(Device));
DWORD error=GetLastError();
if (SUCCEEDED(hr))
CComPtr<ISimpleDevice> _3DxSimpleDevice;
hr = _3DxDevice.QueryInterface(&_3DxSimpleDevice);
if (SUCCEEDED(hr))
// Get the interfaces to the sensor and the keyboard;
g3DSensor = _3DxSimpleDevice->Sensor;
g3DKeyboard = _3DxSimpleDevice->Keyboard;
// Associate a configuration with this device
//_3DxSimpleDevice->LoadPreferences(_T("SpaceMouse"));
// Connect to the driver
_3DxSimpleDevice->Connect();
cout << "*********************************************************" <<endl>get_Type(&type);
cout << "Devicetype : " << type << endl;
cout << "*********************************************************" << endl;
Sleep(4000);
// Create timer used to poll the 3dconnexion device
// --------------- data --------------------
//static DWORD s_dwLastDraw = 0;
double *rotx = new double();
do {
//Sleep(25);
system("cls");
if (g3DSensor)
try {
CComPtr<IAngleAxis> pRotation = g3DSensor->Rotation;
CComPtr<IVector3D> pTranslation = g3DSensor->Translation;
// Check if the cap is still displaced
// cout << "angle " <<pRotation>Angle << endl;
// cout << "trans " <<pTranslation>Length <<endl>get_X(rotx);
cout << "rotx : " << *rotx <<endl>get_Length(tr);
cout << "trans " << *tr <<endl>Angle;
if (pRotation->Angle > 0. || pTranslation->Length > 0.)
double timeFactor = 1.;
DWORD dwNow = ::GetTickCount();
/* if (s_dwLastDraw)
timeFactor = (double)(dwNow-s_dwLastDraw)/g3DSensor->Period;
s_dwLastDraw = dwNow;
pTranslation->Length /= ScaleTranslation*Sensitivity;
pRotation->Angle /= ScaleRotation*Sensitivity;
MathFrame FrameTransRot;
MathFrameTranslation(&FrameTransRot, pTranslation->X, pTranslation->Y, pTranslation->Z);
MathFrameRotation( &FrameTransRot,
pRotation->X * pRotation->Angle,
pRotation->Y * pRotation->Angle,
pRotation->Z * pRotation->Angle );
// MathFrameMultiplication( &FrameTransRot, &FrameCube, &FrameCube );
// if ( FrameCube.MathTranslation[2] > NearPosition )
// FrameCube.MathTranslation[2] = NearPosition;
// if (MainhWnd)
// DisplayCube( MainhWnd, &FrameCube, &VGAVideo );
else
// s_dwLastDraw = 0;
pRotation.Release();
pTranslation.Release();
catch (...)
// Some sort of exception handling
} while (1);
// ------------------- deinit --------------------
// CComPtr<ISimpleDevice> _3DxDevice;
// Release the sensor and keyboard interfaces
if (g3DSensor)
// g3DSensor->get_Device((IDispatch**)&_3DxDevice);
g3DSensor.Release();
if (g3DKeyboard)
g3DKeyboard.Release();
if (_3DxDevice)
// Disconnect it from the driver
// _3DxDevice->Disconnect();
_3DxDevice.Release();
return 0;
