AutoCAD Roll Tilt Spin
DavidHellberg
Post by DavidHellberg »
Hi;
Is it possible to get Roll Spin and Tilt to work in AutoCAD ADT 2007 and
AutoCAD Architectural 2008. Right now I can only Pan and Zoom
/David
dkosburn
Post by dkosburn »
You'll need to be in a 3D view style
DavidHellberg
Tilt Spin Roll
I tried a 3D view but it doesent help.
Im using the "Space Navigator".
It doesnt help to change to "Free mode" in
AutoCAD.
Hi DavidHellberg,
Can you rotate using the normal mouse (3D orbit command)?
CanuckChuck
Post by CanuckChuck »
I am experiencing the exact same thing. It is like the switch to allow 3D translations is being ignored.
CanuckChuck
Calgary Canada
Hi CanuckChuck,
Same question: can you rotate using the normal mouse? Is that option available to you in that mode when using the normal mouse?
clarkrj
Post by clarkrj »
I have just installed the program with the latest drivers. This is my first install and I can not tilt roll or spin. all the settings seem to indicate that I should be able to. I am running AutoCAD 2008
Hi clarkrj,
Can you tilt or spin with the normal mouse?
clarkrj
Post by clarkrj »
When I switched to 3D wireframe mode everything works. I can do 3DORBIT in 2D wireframe with the mouse, but not with space navigator. We work (as a standard) in 2D wireframe.
Hi clarkrj,
When you start the "3DOrbit" command, it changes the view to 3D until it terminates. In 3D, you can also rotate with the 3D Mouse.
DHowlett
Autocad Roll,Tilt,Spin
Post by DHowlett »
I am having the same problem.
Yes, it will work in all other programs, but not AutoCAD.
It has tilted, spun, rolled before, but suddenly it doesn't.
I have downloaded & installed new drivers, etc.
On a deadline!!!
Please Help.
D. Howlett
Re: Autocad Roll,Tilt,Spin
Hi DHowlett,
Change to a 3D view and you can rotate.
