hi,
as x.org (http://www.x.org/wiki/Development/Docum ... InputHOWTO) said, "An X driver has to handle three different entities: modules, drivers and devices ".
but, when i installed my spaceball driver in redhat ws 4.0, I couldn't find the module and just a 3dxsrv driver located in /etc/3DxWare/daemon.
so, where is it? And, how to set my device in xorg.conf, as an input( or extension) device?
btw:
we develop a program with following codes:
bool myfunc()
// get the list of input devices that are attached to the display now
XDeviceInfoPtr list;
int numDevices;
list = (XDeviceInfoPtr) XListInputDevices(display, &numDevices);
// now run through the list looking for the spaceball device
int i;
for (i = 0; (i < numDevices) && (strcmp(list.name, "spaceball") != 0); i++)
; // shut up and loop
cerr << "Devices' name: " << list.name << endl;
return (i < numDevices);
the result is:
Devices' name: Keyboard0
Devices' name: Mouse0
Mine xorg.conf is:
Section "ServerLayout"
Identifier "single head configuration"
Screen 0 "Screen0" 0 0
InputDevice "Mouse0" "CorePointer"
InputDevice "Keyboard0" "CoreKeyboard"
InputDevice "spaceball"
EndSection
Section "InputDevice"
Identifier "spaceball"
Driver "/etc/3DxWare/daemon/3dxsrv"
Option "Name" "3dconnexion spaceball"
EndSection
OS: redhat enterprise ws 4.0 (with cmd: uname -a
Linux YFX 2.6.9-34.EL #1 Fri Feb 24 16:44:51 EST 2006 i686 athlon i386 GNU/Linux)
X: X11R6
3dx driver: 3dxware-linux-v1-2-11.tgz
spaceball: spaceball 5000 FLX-A (serial)
thank you very much.
yanfx
where the spaceball module located?
No Spaceball module
Hi yanfx,
our driver 3DxWareUnix is no X module, but more like an application. It is not suitable to be used with the xorg.conf.
There is no need to enter something in the xorg.conf. You just need to install it and that's it. The daemon (3dxsrv) reads the data from the device regardless of which of the supported models it is and sends it via XClientMessages to any application. You should have a look to our Unix/Linux SDK and check the code of the example (xapp.c).
Uta Ludwig
Uta Ludwig
SGI's Open Inventor may be failed with this way
I do appreciate your timely help.
but, uludwig, you must know the 3d toolkit, SGI's Open Inventor. Their class SoXtSpaceball can support the spaceball. But now, as what you said, their support will be invalid??!!! The source code of this class are following:
and now, we build the org. demos (located in $IVROOT/apps/samples/spaceball), spaceball and spaceballViewer, they all tell me:
because the source codes are:
so, your spaceball will not support sgi's open inventor?!!
if not, how to get the string "spaceball" in our system (see my first post, please)?
SoXtSpaceball::SoXtSpaceball(Display *d, SoXtSpaceball::Mask whichEvents)
constructorCommon(d, whichEvents);
void
SoXtSpaceball::constructorCommon(
Display *display,
eventMask = whichEvents;
motionEvent = new SoMotion3Event;
buttonEvent = new SoSpaceballButtonEvent;
// these are empirically good default values
rotScale = .006;
transScale = .006;
int numDevices;
device = NULL;
for (int i = 0; i < numDevices; i++) {
// Open the spaceball device - the device id is set at runtime.
if (strcmp(list[i].name, "spaceball") == 0) {
device = XOpenDevice(display, list[i].id);
SbBool
SoXtSpaceball::exists(Display *display)
int numDevices;
if (display == NULL) {
#ifdef DEBUG
SoDebugError::post("SoXtSpaceball::exists()",
"display is NULL.\n");
#endif
return FALSE;
int i;
(strcmp(list[i].name, "spaceball") != 0); i++)
// if we broke out of the loop before i reached numDevices,
// then the spaceball does in fact exist.
Could not find a spaceball device connected to this display
int
main(unsigned int, char *argv[])
Widget mainWindow = SoXt::init(argv[0]);
if (! SoXtSpaceball::exists()) {
printf("Could not find a spaceball device connected to this display\n");
exit(1);
No Support for Open Inventor
Hi yanfx,
yes, I have heard from Open Inventor from SGI. But as far as I know this application does not support our devices via the API provided by our driver. Long time ago there was support for some of the very old devices (Spaceball 2003 and 3003). This support did not use our driver and was not done by 3Dconnexion.
If you have a question about the source code of Open Inventor you should post them to Open Inventor. They are the right one to help you.
what a pity
as you said and we practise, the result is your driver lost sgi's open inventor.
now, we have to contract with tgs for their open inventor. (of course, others also can contact with coin3d.org for their toolkit.)
thanks for your reply.
