CadMouse and Fusion360 Tips&Tricks
YesPapa
Post by YesPapa »
Does somebody set the CadMouse for Fusion 360 software?
Thank you.
Re: CadMouse and Fusion360 Tips&Tricks
Hello YesPapa,
what exactly do you want to set?
YesPapa
Post by YesPapa »
I want to set all the buttons. When I use the mouse with the software some buttons are not actives.
Radial Menus :
I want to match with front, top, left, right views
Middle Button :
I want to match with orbit when press it and another keyboard
etc.
I want to know how to do it.
Thank you.
Hi YesPapa,
you can find some of the defined views in the list of the button mappings. Open the driver window (3Dconnexion properties) and open the "Buttons" window. Open the list with the functions next to the button that you want to map. Type the command that you are looking for. For example "Top" for Top View. The command will be listed and you can select it.
See as well our help file for explanation about Button Mapping.
There is a predefined Radial Menu "RM Views" which has some of the views already mapped. If you do not see the correct names of the views that is because Fusion 360 doesn't provide them to the driver. This has to be fixed by Autodesk. Please address this issue with the Support Team of Autodesk to let them know that users need a fix.
YesPapa
Post by YesPapa »
Thank you. I have a look at it.
Banonkey
Post by Banonkey »
I'm very green with all of this and was wondering if you could direct me to the "help file" you reference here as well as other posts.
I'm currently trying to setup my cadmouse pro wireless for use in autocad lt and struggling to find guides that accurately depict what I see on my screen. One example, the OSD (on screen display) isn't listed or written anywhere in the settings for my mouse and I just cant quite figure this out.
AmroSalih
Post by AmroSalih »
