3DXWare values language
mlutz
Post by mlutz »
Sounds I got some issue with the 3DXware and Catia V5
My Catia install is using English Language.
3Dxware Control Panel starts with French. I was able to change the Menu Language into English, but the value for the button conf are still in French.
So finally when I want to use a function like "Centrer Tout" (Center All), catia Tell me that it is an unknown Command
How can I fix that
B.R.
Mathieu
Peter
Post by Peter »
Mathieu,
I am not certain what driver version that you are using. We may be able to resolve the problem by reinstalling the 3dx driver (if you have not already done so).
You can download the latest 3dx driver from: www.3dconnexion.com
When you install the driver, be sure to select ENGLISH for the language to be installed.
Peter
mlutz
Post by mlutz »
You're right --- I already did it (took the last dirver + install with the English Language)
The application starts in English but value for the button conf are still in French (which is my windows language, I do not now if this is linked)
rstadie
Post by rstadie »
Hello Mathieu,
you can try the following:
Important: Incorrectly editing the registry may severely damage your system. Only follow the procedure below if you are confident that you understand the instructions. Always make a backup of the registry before editing and make sure that you understand how to restore the registry if a problem occurs!
1) Open your registry editor
2) Navigate to HKEY_LOCAL_MACHINE\Software\3Dconnexion\3DxWare or, if only applicable to the logged in user, HKEY_CURRENT_USER\SOFTWARE\3Dconnexion\3DxWare.
3) Create a new value (as string) named "CATIALocale" (without the quotes)
4) Set the value data to: 1033
5) Restart the driver
Please let us know if this worked for you.
Robert Stadie
mlutz
Post by mlutz »
No change ... values are still in French
mlutz
Post by mlutz »
adding it in HKEY_LOCAL_MACHINE\Software\3Dconnexion\3DxWare
->You were faster than me (I was just testing that ...)
Now it works
Thx for your help
Mathieu
mlutz
Post by mlutz »
For Got My previous message.
I wanted to say that :
HKEY_CURRENT_USER\SOFTWARE\3Dconnexion\3DxWare. it doesn't work
under :
HKEY_LOCAL_MACHINE\Software\3Dconnexion\3DxWare : it works fine
Mathieu
Hi mlutz,
Are you positive about that? The software is meant to work with both sections of the Registry.
Peter06
Re: 3DXWare values language
Post by Peter06 »
Hi guys,
I hope you can help me out with the language issue. I have downloaded following driver 3DxWare64_v10-6-7_r3198.exe and I want to have it in german language. After installation when I run "3Dconnexion Home" it shows me in english language same as all the components EXcluding "Settings". There I have desired german language.
I read and tried things already mentioned --> creating a string CurrentLocale - 1031 in registry, or edit Global.xml in C:\Program Files\3Dconnexion\3DxWare\3DxWinCore\Cfg
Is there a way how to set up german language for all components? Or I am missing something?
Thanks for help in advance.
Hi Peter06,
you can insert a Culture element into your Global Cfg file in Appdata (%APPDATA%\3Dconnexion\3DxWare\Cfg\Global.xml).
E.g., for German,
<Global Default="false" xmlns="">
      <Settings>
            <Culture>de-DE</Culture>
      </Settings>
</Global>
The Cultures we currently ship are:
  • en-US
  • de-DE
  • fr-FR
  • ja-JP
  • zh-CN
