zBrush plugin problems...
ben0bi
Post by ben0bi »
if anyone can help me with this stuff i would be happy:
http://209.132.96.165/zbc/showthread.ph ... post411610
(this is my original post in the zbrush forums)
looks like i need to hack around (if i can). :(
greetings,
ben0bi
01011011 01001011 01001110 01001111 01010111 01001100 01000101
01000100 01000111 01000101 00100000 01001001 01010011 00100000
01010000 01001111 01010111 01000101 01010010 00100001 01001110
Hello ben0bi,
Good luck. ZBrush is probably our number 1 requested application. I had a meeting with the Pres and VP at SIGGRAPH a couple of years ago, but they proved to be 100% unresponsive afterward. It is a VERY cool application...but it really needs to have 3D mouse support.
You are correct in diagnosing the problems you will encounter. Even their "SDK" may not work if it isn't designed to handle continuous navigation in the background (while other code and other plugins are running). It is all too common for application code to assume the view will not change while it is in the middle of doing something...then blow up when its assumptions are broken.
We've been pushing on them, but frankly the only people they listen to are paying customers...
3Dx Software Development
