Beitragvon Josh » Do Nov 03, 2016 7:18 pm
Hi there
I searched the forum for help in my specific problem but didn't find a solution. If there is any post out there which solves my problem I would appreciate your hint.
I would like to do the following: I would like to bind a keyboard key with a modifier to the rotation axis of my SpaceNavigator, lets say Control+ArrowDown to HIDMultiAxis_Rx.
I am able to realize the simple key generation with the follwoing code:
<Axis>
<Enabled>true</Enabled>
<Input>
<Min>-512</Min>
<Max>0</Max>
<Deadband>100</Deadband>
</Input>
<Output>
<RepeatStyle>PressAndHold</RepeatStyle>
<Reversed>false</Reversed>
<KeyStroke>
<Key>51</Key>
</KeyStroke>
</Output>
</Axis>But when I try to implement the 'Control' Modifier as follows:
<Axis>
<Input>
<Min>-512</Min>
<Max>0</Max>
</Input>
<Output>
<KeyStroke>
<Modifiers>
<Modifier>Control</Modifier>
</Modifiers>
<Key>51</Key>
</KeyStroke>
</Output>
</Axis>
Is there any way to bind a Modifier+Key to the axis?
