SpaceNavigator PE(USB) pan and rotate crazzy
Tomludd
Post by Tomludd »
The Jet in Jet Demo Spin towards you, by just touching the SpaceNavigaor, and in every other application i use. javascript:emoticon(':cry:')
The spaceNavigator Pan right, Pan Down, Zoom Forward, and Spin right, at the same time, just by touching it. If i reverse all axes the result is the reverse...
It's doing it for 2 seconds even if i just have touched it for an half second.
I've tried to restore all defaults, and Calibrate, in all profiles
also i tried disconnecting it and connecting it in a other USB port and restarting the drivers.
Yester day it din't work, and i disconnected it many times and I made it work once but when i restarted my Computer to day it did'n work, anny more.
I tried it on a other computer and there it worked perfectly, but on my own computer it won't make anny god.
I have also updated the driver to:
Release Version 3.6.4
Driver version 6.6.1
Firmware Version 3.18
I use Windows Xp SP2 (32-bit x86)
Do you have anny solution for me :?:
--==Tomludd==--
I've seen this before. I can't recall exactly what it is. It is something simple though like 2 drivers running at once. While I am racking my brain, do the following:
Uninstall 3DxSoftware.
Delete siappdll.dll and spwini.dll from your System32 directory.
Delete the contents of HKCU/software/3dconnexion/3dxware/applications
Delete all your saved profiles in %appdata%/3dconnexion/3dxware/profiles.
Reboot.
Reinstall 3DxSoftware.
3Dx Software Development
Tomludd
Post by Tomludd »
It did not help anny thing... the same problem is still happending.
But I could not do the following because the files did not exist after uninstall.
jwick wrote: Delete siappdll.dll and spwini.dll from your System32 directory.
--==Tomludd==--
Tomludd
Post by Tomludd »
Now i have tried to reinstall my computer and then the spacenavigator works fine... i do not know what could have been disturbing the spacenavigator
Thanks for trying to help.
--==Tomludd==--
