Splash screen shows up when SW has an error
NeoCowboy
Post by NeoCowboy »
Hi all,
I just got a SpaceExplorer in January and have been using quite a bit. The one thing I have found that is a little anoying is that when I do something that SW dosn't like (usually involving a design table or rebuild error) the splash screen comes up for the 3d controller and won't go away. I have to turn off the add-in in SW to make the spash screen go away and when I start it up again the splash screen comes back and won't go away. This stays until I restart SW. Has anyone else seen this problem in this program or in other programs using the 3d controller?
If you have seen this problem is there anyway to fix it or keep it from happening?
Ethan
"I used to want everything, then I though "Where would I keep it?""
- I can't remember the guys name, something Wright I think"
Re: Splash screen shows up when SW has an error
hi NeoCowboy,
Check the on-line help file ("3Dcontrol" toolbar, "question mark" icon).
There's an option in the 3Dcontrol add-in "properties" to control the banner.
