The 3D-Lock button on the Spacepilot does nothing in the 3D environment of Inventor 2008 and 2009. It doesn't show up in the Control Panel either.
(with my space-explorer everything is fine)
SpacePilot 3DLock not working in Inventor
Please try the following:
1. Stop 3DxWare and disconnect your 3D Mouse
2. Go to %appdata%\3Dconnexion\3DxWare\profiles
3. Create a new folder named "backup" and move all .scg-files there
4. Connect your SpacePilot and start the driver
Does it work then? If not you could also create a new user on your machine and check if the problem depends on your user-profile or not.
Robert Stadie
