After installing the updated driver the function of my SpacePilot is not as smooth and will only move in one plane at a time. I had no problems with Inventor 2009 before the driver update.
I am using Vista Business 64 bit and Inventor 2009
Any help is appreciated.
Installed updated driver 3DXSOFTWARE3.6.4 and have problems
Please open the Button Mapping Editor and go to "Device Settings". Is "Dominant"-mode enabled there?
You could also try to start with a clean Inventor-configuration:
1. Stop 3DxWare and disconnect your 3D Mouse
2. Go to %appdata%\3Dconnexion\3DxWare\profiles
3. Create a new folder named "backup" and move all .scg-files there
4. Re-connect your 3D Mouse and start the driver
Please let us know if this procedure helped.
Robert Stadie
