Hey all,
I'm currently accessing the SpaceNavigator using the WM_INPUT method, and that works very well. Unfortunately, since the driver is never loaded, the LEDs are always turned off. I'd like to control them.
And there's the problem - I have exactly zero experience with HID programming. So as far as I could gather from MSDN, I have to send some kind of HID report (which looks like a binary stream) to the device using WriteFile. Unfortunately that's about as far as I got. There seem to be a lot of conflicting information on how exactly that report has to look like, how it has to be built, send to the device, etc. I tried lots of different approaches, and all failed.
I'm a little lost right now, to be honest. So any help on how exactly I can control these LEDs would be very much appreciated !
- Alex
Controlling SpaceNavigator LEDs over HID
There are some HID programming examples on:
ftp:/ *** ***
login: ***
password: ***
Moderator Edit: the sample code is no longer available from the FTP service. Please contact 3Dconnexion API Support if you need further assistance.
ftp:/ *** ***
login: ***
password: ***
Ah, I didn't notice the rezero example. Modifying it for LEDs did the trick. Thanks !
However, I still have a question. As I mentioned, I'm using the raw input method to get the controller state. I support multiple controllers, ie. enumerate available raw input devices with the right vendor and product IDs, and let the user pick the one he wants to use with our product. I then only process WM_INPUT message originating from the corresponding input handle.
Of course I'd like to enable the LEDs for the selected controller only. But right now, I can't find a way to match the devices I get from the raw input device enumeration (GetRawInputDeviceList) with the HID enumeration (as in the rezero example). There is just no common data to compare: the returned device handles are incompatible, and the VID/PID are not enough to differentiate two identical devices.
Is there some kind of serial ID one could use, or somehow match both enumerations for identical devices ?
- Alex
- Alex
Hmm, I see. Well, it isn't that much of a problem really. But it would still be very convenient to somehow being able to match the devices in a future driver or product revision (although I guess this is more a limitation of MS' current rawinput API, which looks very limited in terms of returned device information).
Thanks for your help,
Alex
Alex
