Good morning.
I have purchased your space navigator if, I have installed your last release of driver and I have installed the various drivers. I use 3dstudiomax8 and me I have not succeeded in making to correctly work spacenavigator. The driver is slow, it doesn't correctly work, I have attentively followed your indications of installation of the peripheral one. The problem concerns only 3dstudio because is the demos that the plugin for photoshop they work.
I will try to explain the problem to the best: The driver works only if I launch the application from the toolbar but it is slow and when I apply any transformation in 3dmax your driver goes to block, if I try to close the interface he/she writes me emptyerror, some times your driver forces me to finish the application.
I have more times reinstalled the drivers also manually but the problem persists in 3dstudio the spacenavigator it works only when I open 3dconnexioncontrolpanel and as soon as with the mouse touch an any button in max everything returns to jam. I don't know anymore now thing to do for resolving the problem. I repeat that the spacenavigator doesn't work only in 3dmax, all the other applications correctly work, I have also tried to install again Max not inserting plugins of any type because I could think to a possible conflict with them, but no self I have resolved.
I have purchased the spacenavigatorse to make a will it before making a supply for everything of my study and I have maximum interest to use him in 3dsmax.
My computer:
Dellprecision670 dualxeon 4gbramm
windowsxp professional service pack2
I have your mouse laser mx and one keyboard of yours and other peripheral logitech because I am a faithful client.
Use 3dmax8 no service pack
Vray render
I hope that someone helps me
Excuse me the English they are not very good Graces
www.lsudesign.com
Help 3dstudio max8
Help 3dstudio max8
Hi umblas,
please remove the driver you installed and install it again as an administrator. I don't exactly unterstand what could happened, but removing and re-installing the driver makes sure, that nothing could go wrong.
Please try to use your application after this re-installation. Afterward please post how it works.
By the way, could you specify which driver do you use for 3ds max?
