SpaceNavigator and CosmosDesignStar 2008
I just installed CosmosDesignStar 2008, but the 3Dconnexion driver (3.6.
does not work with it yet. I tried to load the SolidWorks driver manually ("File"->"open"->"TDxSW.dl"l) without success (DesignStar crashes). I can't imagine working with DesignStar without my SpaceNaviogator, so I would like to know if there is a solution to make it work till 3dconnexion releases an upgrade of the driver. Thanks in advance for your help.
It seems the installer failed to properly register the add-in for DS.drspock wrote:3Dcontrol is not in the add-in manager at all.
Logged in as an administrator, open a command-prompt, change directory to where the "TDxSW.dll" file is stored (normally this is C:\Program Files\3Dconnexion\3DxSoftware\3DxSolidWorks" and run the command "regsvr32 tdxsw.dll". Launch DS and see if you can find the 3Dcontrol add-in on the add-in manager panel.
I am running windows XP professional version 2002 SP2.
DesignStar is version 2008 SP0.0.
3Dconnexion is release version 3.6.8, driver version 6.6.1 and firmware version 4.04.
Computer is a DELL Precision PWS390 Quad [email protected], 2.00GB of RAM.
I had the following message from 3Dconnexion email support:
Thank you for your help, but if it is really too compicated, I will wait for the driver update...
Without successSpace navigator PE user only get forum support.
http://www.3dconnexion.com/forum/
Create an account
Login
post 1 time in the test forum.
This will allow you to create new post and you can get answers to your questions.
Cosmos Design star 2008 is currently not supported.
The programmers are still testing it.
What you can try is load the 3dconnexion solidworks plugin manually.
Go to Tools
Addins
Browse to:
C:\Program Files\3Dconnexion\3Dconnexion 3DxSoftware\3DxSolidWorks Locate and click on TDxSW.dll
This will load the addon.
Bug #4808 is the problem with the automated installation. You can workaround that by "drag-and-drop" the TDxSW.dll file into a running instance of DS. The TDxSW.dll is normally located under "C:\Program Files\3Dconnexion\3Dconnexion 3DxSoftware\3DxSolidWorks".drspock wrote:Does it means that I have no choice but wait for the update?
The updated is planned to be made available before the end of the month.How long is it supposed to take to get the update?
Let us know if the above "drag-and-drop" workaround enables you to use your 3D mouse in DS.
I'm sorry. I should have made that more clear (I've edited my previous post).drspock wrote:The .dll has to be in which folder?
From Windows Explorer, you should drag the TDxSW.dll file and drop it into a running instance of DesignStar (not into a folder). An alternative method (as the our support line suggested) is to, from DS, go the "File" menu, select "Open", select "All files", browse to the location of the TDxSW.dll file, select it and press the OK button. This will load the add-in into DS in a similar way to the drag-and-drop method.
That seems to be a separate issue. We cannot reproduce the crash in DS2008. We'll be running additional tests on different hardware and see if can see anything like you reported.drspock wrote:3D mouse software looks like it wants to open, but after a while, it makes DS crash without opening.
Note that DS2008 is based in SolidWorks 2008 and we use the same add-in (same file) for both applications. We can have had no crash reports in SW2008.
An updated: the fix for issue #4808 (add-in installation in DS2008) was included the 3DxSoftware v. 3.6.10 release of last week.
The software is available for download here.
drspock: we re-ran our testing procedures in different hardware and we cannot reproduce the other problem that you reported (application hang followed by a crash).
