This is mainly directed to 3dconnexion driver developers.
I'm using AutoCAD 2009 and when in paper space when you lock the Scale ratio.
If you move the 3d connexion mouse while its locked the mouse will move and zoom the drawing, instead of panning it.
I tried to understand and reproduce this, but it seems to work for me.
This is what I tried:
A) Open 3D House.dwg sample file
B) Got to paper space
C) Open Properties and select the viewport
D) Set "Standard scale" to 1:50
E) Set "Display locked" to "Yes"
F) Doubleclick in the drawing and verify 3D mouse moves the paper, not the view (works)
Could you please explain what must be done to reproduce the issue?
Ok, you locked the display and you double click the viewport to get into the model and your mouse will not pan it will zoom in and out as usual when it should be just panning to keep the scale correct.
You mean if the view is not locked (which should prevent the view from being changed) but the scale is constant you should be able to pan the drawing but you don't want to zoom/unzoom?
Currently the issue we are having is that we do not see the issue you describe. With the property 'Display Locked' set to 'Yes' only the paperspace view is pan and zoomable.
