Maya rotate about sub object. i.e. vertex
I notice in Maya, when an object is selected the rotate is centred around its pivot point, which is great.
But if I go into Vertex suboject mode for example and even if I select a vertex and FrameAllSelected the rotate centre is still around the object pivot point rather than around the selected vertex (as using alt+LMB would do). This makes it very difficult to navigate in a sub-object selection of a large piece of geometry.
Please advise, Thanks.
Dan
Dan
Heollo, I have Maya 2008 and Space Explorer USB
I've noticed that if I turn fly mode off it does pivot around the sub object. But of course this involves a click, and the rotation and translation speed is much slower.
Is there a script available that automatically turns fly mode off in sub object mode and keeps the rotation / translation speed more or less the same?
That would be ideal.
Dan
Dan
Hi Robert
For object mode navigation I prefer to have these settings
Maya Control panel
View: Camera
Rotation Pivot: Scene / Object
Flymode on
Disable rolling on
All other tick boxes off.
3DConnexion Control Panel
Reverse All Axis
Sensitivity on Pan up and down reduced, and referenced to up / down on control knob.
With these settings I can quickly and easily navigate the scene, and whatever object I select becomes the rotation pivot.
Try creating a very long box, go to vertex mode and select the 4 verticies at one end, click frame selected (fit) so you are zoomed in on the area, try to rotate and you will notice that the verticies swing wildly away from you. This is because the rotate pivot is still that of the object. What I would like is the rotate pivot to be a mean average of the verticies selected, i.e. in the middle space of all the verticies selected. This is how I am accustomed to work in 3D Max, I have only recently switched to Maya and 3D space explorer.
Many thanks
Dan
Maya Control panel
View: Camera
Flymode on
Disable rolling on
Reverse All Axis
Many thanks
Dan
Yes, I have tried working with focal point, but I don't find it as practical/easy to work with because it's not a fixed point in space. When you are selecting a group of sub objects you are saying you want to work in this area, hence it makes sense to make that the rotation point (focus of attention).
You have it set up like this in Scene / object mode, it is a real shame that this doesn't translate into subobject mode.
Also Maya does do this as standard, if you select a bunch of verticies and "fit to frame" using Alt+LMB the pivot of rotation is the mean of the pivot points of all the verts.
Please make this a feature.
Cheers,
Dan
Cheers,
Dan
I think you will find that 'fitting' causes the group of vertices to be placed around the focal point or center of interest. Using Alt + LMB simply rotates about the center of interest. Setting the pivot in the 3D mouse to focal point and switching off translations causes the 3D mouse to behave exactly the same.3dan wrote:Also Maya does do this as standard, if you select a bunch of verticies and "fit to frame" using Alt+LMB the pivot of rotation is the mean of the pivot points of all the verts.
Does this not work for you?
OK I see what you are getting at
This is my normal method for navigating (keyboard and mouse) in more detail. Say I have a very large environment scene:
I select the object I want to work on, a tall building. I select it, I hit 'F' fit to frame. I want to work in a corner so I go to Verts mode, select a bunch of verts in that corner and hit F again. {OK, after trialing I agree the centre of interest is not fixed. } I now zoom back to my desired working distance, And this is where it is different,
when I zoom out with the mouse wheel and rotate the center of interest, or the rotation pivot remains where it was. when I zoom out with the space explorer the rotation pivot remains at the focal point of the camera. [Generally far too close!]
This means that although I will tend to Alt+MMB pan around my rotation pivot stays in generally the correct position. and after I have been working for a while sometimes I do want to reset my roation pivot, but normally it is good enough until I have finished with the verts in that area.
So is it possible for the rotation pivot to remain independant of the zoom level? I am guessing that forward back actually translates the camera position, so hopefully it would be simple to replace that with camera zoom.
You mention, to turn off translation, but it seems that only leaves me with rotation, although I don't mention it earlier, I do need to zoom and pan also.
I look forward to hearing from you, Thanks
Kind regards
Dan
Kind regards
Dan
Thanks, we are moving closer to the root of the problem.
Turning fly mode off is almost perfect. One problem remains, one functionality is missing, Now I cannot pan.
I would like:
View: Camera
Fly mode: Off
Up/Down Axis: Zoom (or Off, to be controlled by the mouse wheel)
Forward/Backwards/Left/Right: Pan
Tilt/Spin/Roll: As normal, Twist/Turn
Dan
I would like:
View: Camera
Fly mode: Off
Dan
This I cannot reproduce. The spin is designed to be a constant angular velocity for a given cap twist about the center of rotation.3dan wrote:Also I notice in Flymode that if I look top down on the geometry and rotate, the geometry will spin much faster than if the camera is near the horizon, (near y=0) , while in the case of keyboard and mouse the rotation speed is always directly proportionate to the distance travelled by the mouse.
