Is there anyone who has the Spacenavigator within Windows 7?
The latest driver (with Vista support) should be sufficient, but I can't get the Spacenavigator working.
Spacenavigator working with Windows 7
Best regards,
Bert
Bert
Space Navigator withWindows 7
I have the same problem - the led's on the navigator are not lit up & when I try to start the driver nothing happens - if I pick stop driver a dialogue box comes up to tell me that the driver isn't started.
I've tried Vista & XP compatibility mode but that does not work either
kuantokusta
Please create a logfile and send it to me (you will find my contact data in your Inbox).
A) Open a command-line prompt
B) CD to C:\Program Files\3Dconnexion\3Dconnexion 3DxSoftware\3DxWare\
C) Execute the following command:
You will then find the logfile (named "3DxWare.log") in the following location:
C:\Users\Your_Username\AppData\Roaming\3Dconnexion\3DxWare\
3dxsrv.exe -logC:\Users\Your_Username\AppData\Roaming\3Dconnexion\3DxWare\
Robert Stadie
My configuration:
CPU: Intel [email protected]
OS: Microsoft Windows 7 build 7231
PE driver: 3DxSoftware v. 3.7.16
3D Application: 3dsMAX-2010
With the installed driver, all is going fast and fluent.
amelia
amelia
Jooz,
Please use this topic for all Windows 7 issues.
Does the SpaceNavigator work on another machine?
Robert Stadie
