MIDI Navigator v1.1
MIDI Navigator v1.1
I just uploaded a new version of my MIDI Navigator driver.
MIDI Navigator is a program that translates Space Navigator movements to MIDI control change messages, allowing the user to control a number of audio (and some video!) applications with it.
New in version 1.1 are the choice of MIDI channel, relative or absolute mode and sliders for sensitivity. The change under the hood is that it now uses the OS X beta driver instead of the USB HID interface to talk to the hardware.
Downlaad it here
Downlaad it here
wow
great work stew! been fiddling with reaktor and the SN for 2 hours with this.. just can't say how much i appreciate your work! limitless creative possibilities for the electronic musician
it's such an amazing sensible device, you can make very organic smooth changes to the pitch, timbre, volume, duration, frequency modulation... it's really a breaktrough
edit: here's a small example: http://www.bbox.tv/snmidi.html
kudos,
rui gato
Edit (moderator): the site seems to be down. The clip (very cool!) is also available from YouTube:
http://www.youtube.com/watch?v=KLT0fkWna6E
kudos,
rui gato
Hi alecks,
i did the video myself, and used ableton live + reaktor to make this example:
www.ableton.com
www.native-instruments.com
but you can achieve this kind of results with any virtual instrument that accepts midi CC's
for the translation, you can try Plogue Bidule
greets,
Rui Gato
www.ableton.com
greets,
Rui Gato
Hey,
Thanks for the info, I'm looking into those now. I'm not really an audio guy by any means, but i've recently discovered midi and other devices (arduino, processing, etc...) and am fascinated by it all, so i'm trying to absorb as much as possible.
The MIDI Navigator outputs CC messages. How do you turn those into notes?
I just downloaded Bidule and am trying to do it there. Is Bidule capable of created something similar to what you did in that video, where little taps create different sounds (or the same sound but different pitches? i don't even know)...
Thanks much
-Alex
Thanks much
-Alex
I noticed the new driver induce a drop of sensitivity in your Midi Navigator, is this normal?
As it blocked ControllerMate to work properly, I came back to the last driver (or nothing at all, don't remember how far I went last night to recover things working together).
Stew, I eagerly wait for you Poser 7 plugin. Man, this will be exciting!!
All the best,
GregVDS
All the best,
GregVDS
All the best,
GregVDS
GregVDS
ControllerMate is not an officially supported application but I tried ControllerMate v4 with v1.0.1 of the driver and it seems to work fine. Is there a specific issue you're seeing?
As far as the sensitivity, please see viewtopic.php?t=537
