Pro/E WF2, M210: Buttons open panel instead of function
duffy6
Post by duffy6 »
with my new SpaceExplorer the defined buttons do not execute the desired action. Instead the buttons opens the panel window and no action is executed.
Can you help?
Thx.
Greetz,
duffy6
agoenczi
User
User
Post by agoenczi »
Hi duffy6,
you should use the plug-in to map the desired functionalities to the various keys. In Pro/E you have a special menu called 3DxProENGINEER (this launches the plug-in) which configures your 3D navigation device or you can list the content of the help.
duffy6
Post by duffy6 »
Exactly this is the way I did.
But when I push a button nothing happens except the 3d ware panel pops up.
Please help!
regards,
duffy6
agoenczi
User
User
Post by agoenczi »
Hi duffy6,
Please check the functionality of the buttons with another application (for example Google Earth). Try a button-mapping.
If it works in Goolge Earth, but not in Pro/E WF2, remove your 3DxWare and install it again.
If it doesn't work correctly, please contact the customer support of 3Dconnexion at:
http://www.3dconnexion.com/support/contacts
Hi duffy6,
This could be a saved configuration from a previous 3DxSoftware release (if you had a previous device). Open the 3DxWare panel and reselect the default Pro/E configuration while Pro/E is running.
Let us know if this helps.
3Dx Software Development
