Having issues with spacepilot pro need HELP.
KentaGenshio
Post by KentaGenshio »
So I'm having this issue with the spacepilot pro after installing the latest drivers it works perfectly fine at first but once I either close the program that I'm using (lightwave) the mouse stops working for that program or if I try and macro the keys it will also stop working for that program (lightwave). If anyone can help me trouble shoot this problem It would be greatly appreciated.
Re: Having issues with spacepilot pro need HELP.
Contact tech support. You probably need a cfg for LightWave. They will want a log file from the driver.
lardbros
Post by lardbros »
I have the same thing, and even with the latest drivers, 10.5.2, it still doesn't work.
I've sent log files each and every time a new driver is released, but still, no dice.
I've also contacted Newtek/LightWave support and they are keen to fix it if they can, but would need a developer contact at 3d Connexion.
Is there anyone at 3d Connexion whose details I can pass on to the dev at Newtek?
