I´m using a Spacemouse Pro with SolidWorks 2017 (running with Windows 10). I updated SolidWorks (ServicePack 4.1) and since then I can´t use the ESC CTRL SHIFT and ALT buttons. Even if I configure it with a Solidworks command, it doesn´t work... All the other buttons work fine and are configurable. I updated the driver but it doesn´t fix this issue.
Has anybody had the same issue?
Thanks!
Problem Keyboard Buttons SolidWorks
Re: Problem Keyboard Buttons SolidWorks
Hello Mathieu,
please check if removing the existing settings solves the issue. See here how to do that.
Thanks for your answer UtaSH, I followed your instructions but it didn´t solve the issue.
I reinstalled the previous drivers (10.4.10) and it works perfectly fine! I guess the programmers will have some stuff to fix for the next driver!
Mathieu
Mathieu
I had the same issue and followed your advice of installing previous drivers. Worked like charm!
Thanks utash for the content you share with us.
