Hi
I'm using a spacepilot on win7-64 and i'd like to map 1/2/3 buttons to mouse buttons (1=right 2=middle 3=left) as default profile. I set profiles for most of my applications and that works OK but i'd like to set it for EVERYONE. How could i set or modify default profile ?
Default profile
Re: Default profile
You can assign them in your Global cfg, and they will be overwritten for all applications.
You have to do that by hand. You can copy the settings from one of your already modified application-specific cfg files in %localappdata%.
Re: Default profile
Hi, may you be more specific?
I only found a Global.xml file in roaming directories, is this the one i need to alter or do i need to copy it in local cfg directory?
Then, global.xml file has not the same structure as app.xml files. Which XML section do i need to copy and in what location?
Here is my global.xml file:
And an app.xml i need to make standard
<?xml version="1.0" encoding="UTF-8" standalone="no"?><Global Default="false" xmlns=""><Settings><LEDsEnabled>false</LEDsEnabled><LogLevel>0</LogLevel></Settings></Global>
-<AppCfg ThisFileVersion="2.1" CfgFormatVersion="1.2" xmlns="" Default="false">
-<AppInfo>
-<Signature>
<Name>STR_EXCEL</Name>
<ExecutableName>EXCEL.EXE</ExecutableName>
<Transport>S80</Transport>
</Signature>
<Options/>
</AppInfo>
-<CfgProperties>
<InheritsFrom>STR_EXCEL</InheritsFrom>
</CfgProperties>
<Settings/>
-<Devices>
-<Device>
<Name>SpacePilot</Name>
<VendorID>46d</VendorID>
<ProductID>c625</ProductID>
<InheritsFrom>Standard 3D Mouse</InheritsFrom>
-<ButtonBank Default="true">
<ID>Default</ID>
-<Button>
-<Input>
<ActionID>HIDButton_1</ActionID>
</Input>
-<Output>
<ActionID>HIDMouse_Right</ActionID>
</Output>
</Button>
-<Button>
-<Input>
<ActionID>HIDButton_2</ActionID>
</Input>
-<Output>
<ActionID>HIDMouse_Middle</ActionID>
</Output>
</Button>
-<Button>
-<Input>
<ActionID>HIDButton_3</ActionID>
</Input>
-<Output>
<ActionID>HIDMouse_Left</ActionID>
</Output>
</Button>
</ButtonBank>
</Device>
</Devices>
</AppCfg>
Re: Default profile
Copy that Devices section (everything including the <Devices>.....</Devices>) to the Global.xml file. Put it just before the closing </Global> element. Make sure those "-" signs are not copied.
Re: Default profile
That works, thank you very much !
