I have just got a new machine running Win7 64-bit. The first time I installed it the SpaceNavigator ran well but the next time I booted the machine the drivers wouldn't start and now that is the case every time I boot the machine. The issue is the same as a previous post (see viewtopic.php?t=2961) but no solution was suggested for this problem. The device is not seen in devise manager anymore. I have downloaded the 3.8.3 driver with no success and have also tried using older drivers, again with no success.
I actually had this problem on my old XP 32-bit machine but found if I had the USB plug out of the machine when I turned the power on then put it in during the booting process the driver would start fine, however this trick doesn't work for Win7.
Please help.
Drivers wont start in Windows 7
