SolidWorks part movement in "Z" direction
Bowtie Bob
I just did a clean install of Solidworks 2010 and my SpacePilot drivers, and I noticed that I'm no longer able to move my parts in assemblies in the "Z" direction (toward/away from the screen). Was this removed in the latest driver update, or am I missing the setting that allows that?
Checking your motion settings in SolidWorks
Dear Bowtie Bob,
In SolidWorks you would want to check your settings under the 'Option' Tab in the '3Dcontrol Properties' Windows. Look under the '3D Control' Menu in Solidworks and choose 'Properties'.
You may also check your settings in the '3Dconnexion Control Panel'. Under the 'Advanced Settings' Tab, make sure all your motions are checked on.
Sincerely,
Bryan
Sincerely,
Bryan
Bowtie Bob
What do you find checked under the Advanced Tab?
Dear Bowtie Bob,
'When you go to the 3Dconnexion Control Panel (Start, All programs, 3Dconnexion, 3Dconnexion 3Dxware), is the z-axis unchecked under the Advanced Tab?
Sincerely,
Bryan
Sincerely,
Bryan
Re: SolidWorks part movement in "Z" direction
Hi Bowtie Bob,
there is a reason why it is not possible to move along the Z direction in subpart movement. It is described in Dassault's SPR 134867:
I do have an undocumented (an not officially supported
) workaround for you:
Whether this affects you or not depends on the assembly document being edited and your version of SolidWorks.SPR 134867 - Model faces become transparent when moving assembly component towards and through viewing plane.
- - Exit SolidWorks (this is important);
- Open the Registry Editor and go to HKEY_CURRENT_USER\SOFTWARE\3Dconnexion Add-In for SolidWorks\;
- Change the value "SubPartMoveAlongZ" to "1" (one);
- Exit the Registry Editor;
- Start SolidWorks, load an assembly and check that you can now move a component along the "z" direction.
