Autocad 2015 Pan-Zoom not available
Gth
Post by Gth »
Greetings,
3D Mouse Wireless seems not to work with Autocad.
No Zoom or Pan available in 2D view/model.
As far as I remember these function were available in previous (few years ago) versions.
Is there any possibility to get it work at present?
Thank you in advance.
Re: Autocad 2015 Pan-Zoom not available
Hi Gth,
this could be the issue the we are tracking with our internal number #7369: No Navigation in Layout mode when navbar disabled.
  • When the navigation toolbar is disabled, 3D mouse movement is disabled in the Layout mode. In order to restore 3D mouse functionality, the NAVBAR command can be used to set the display of the Navigation Toolbar to “ON”.
See if the workaround (enable the navbar) solves the problem. If yes please report this issue to Autodesk/ AutoCad's Support Team. The navigation in AutoCAD had been implemented by Autodesk and only their development team can solve this.
Enable Navbar.png (120.15 KiB) Viewed 3617 times
